1 of the 2 lights for the license plate is out
from memory I think these are festoon type bulbs, ie they have pointed metal ends. I have found before that if you just rotate the bulb slightly in its holder it can make the difference between it working or not working. You described the bulb holder as loose, but I don't know if you mean it's loose from the car, or the bulb is fitting loosely. If the bulb is loose you can GENTLY squeeze the two metal tabs that are the bulb holders together to make the gap smaller and make the bulb fit tighter. Wiring wise both lights are supplied from the same power source and ground, so the problem must be local to the bulb or the holder.
Thanks!
Yes, there is only 1 loom running off the trunk lid ito the car, it runs down the right hand hinge (standing behind the car looking forward) I had a different issue (no trunk lights) and it was because of a cracked wire in this loom. You need to remove the loom insulation at the point where the loom comes out of the plastic hinge cover to inspect the wires.
Thanks, that will be my next project.
So I was thinking instead of having to remove more things trying to trace those wires how about I just tap 2 wires from the working light wires to the bad socket to make a serial connection?
That would work, but it is almost 100% certain you have some kind of issue already with your boot loom running down the hinge. If you don't address it, it will get worse and other things will start to fail. There are a lot of threads on here which start off with "I have this very strange behaviour that I can't understand, ie security system not working, car alarm won't arm, I can't get into the trunk, my trunk lights don't work", and all have the same root cause..... a short or break in the boot loom. It's an easy 1 hour job..... best to do it now (and not run into the one of the other problems in the middle of nowhere, etc)
Richard_gib
09-12-2015 07:08 PM
