100% accurate test...
...or can it still be something else?
Fuel pump the problem or something else?
Test-
If relay is bypassed with jumper wire, does that eliminate all the other things that can impede fuel pump from working? In other words with a jumper in place (and assuming no open wires from there up to pump connector) if pump still doesn't work it HAS to be bad fuel pump?
Is this a 100% good test ????
Test-
SoCalJagS
09-27-2015 09:20 AM
