12.28 @ 117 mph 1/4 mile
#61
#63
Greetings!
Is this housed within the stock 14 HU casting from the V8- with the standard V8 3.06 ratio crown wheel and pinion? How many splines are in the carrier for the diff? 19 as per old 15 Hu and old Dana 44?
What are the bolt sizes in the carrier and crownwheel? Are they 10 x 15mm bolts all around like on the older 15 HU casting?
Im currently looking into renovating the old 15 Hu with dana 44 internals but using 30 splines for strength and so I can use an eaton true trac or torsen
#64
Count Iblis (11-26-2014)
#65
Greetings!
#66
I'm working with the 15 HU as a base unit. The 14 HU just makes me think of the useless ones who worked on it. The 15 HU uses a 8.5 inch crownwheel and is compatible with the the older 4 HU which is indestructable. The 14 HUs crownwheel is under sized.
I'm looking into doing a lot of custom machine work.
The Quaife gives other options. What kind of price range are we talking?
And for the OS Giken?
#67
Thank you very much gentlemen.
aholbro1
08-05-2021 05:02 AM
