12.28 @ 117 mph 1/4 mile
Old 09-16-2013, 02:49 PM
Badbenz94's Avatar
Congrats Steve!!
Did you do the 4.2 swap? Or is this an original engine?
  #62
Old 09-16-2013, 03:19 PM
SteveM's Avatar
Original 4.0 engine. Still with the stock MAF.
  #63
Old 11-24-2014, 06:55 PM
Count Iblis's Avatar
Originally Posted by SteveM
Funny you should ask, I installed an OS Giken lsd just last weekend
Greetings!
Is this housed within the stock 14 HU casting from the V8- with the standard V8 3.06 ratio crown wheel and pinion? How many splines are in the carrier for the diff? 19 as per old 15 Hu and old Dana 44?
What are the bolt sizes in the carrier and crownwheel? Are they 10 x 15mm bolts all around like on the older 15 HU casting?
Im currently looking into renovating the old 15 Hu with dana 44 internals but using 30 splines for strength and so I can use an eaton true trac or torsen
  #64
Old 11-25-2014, 05:15 PM
SteveM's Avatar
Yes, that's the stock 14 HU. Everything is stock other than the lsd. I had Coventry West install it. That lsd was designed to work with the Jag 14 HU.
Count Iblis (11-26-2014)
  #65
Old 11-26-2014, 10:36 AM
XJR-99's Avatar
Originally Posted by Count Iblis
Greetings!
When Quaife was installed to my car, I got first wrong part - it was for 15 HU with 19 which did not fit. 14 HU has 25 and fitted well with right part. The shop was talking about "25 grooves" Here details for the right Quaife:
File Type: pdf
  #66
Old 11-26-2014, 11:53 AM
Thank you very much gentlemen.
I'm working with the 15 HU as a base unit. The 14 HU just makes me think of the useless ones who worked on it. The 15 HU uses a 8.5 inch crownwheel and is compatible with the the older 4 HU which is indestructable. The 14 HUs crownwheel is under sized.
I'm looking into doing a lot of custom machine work.
The Quaife gives other options. What kind of price range are we talking?
And for the OS Giken?
  #67
Old 11-26-2014, 01:03 PM
XJR-99's Avatar
Racing Green Jaguar. - XJ V8 1997-2003, Differential, Limited Slip . Quaife do not sell QDF5W directly( this was at least three years ago ). You may get it from a few special resellers. QDF1W which is for older 15 HU you can buy from Quaife webshop.
  #68
Old 11-26-2014, 08:58 PM
SteveM's Avatar
I believe the OS Giken was retailing for $1800. I got a deal for several hundred less.
  #69
Old 11-26-2014, 11:34 PM
grandell's Avatar
Stop making me jealous
aholbro1
08-05-2021 05:02 AM
dsnyder586
04-04-2019 02:38 PM
dickc
09-08-2015 08:15 AM
AL NZ
09-04-2015 08:39 PM
XFR_Gold
09-02-2015 12:24 PM
Quick Reply: 12.28 @ 117 mph 1/4 mile
