12 volt switched source
If I am correct you have a 1998 XJ? If this is correct this oneline will help http://www.gusglikas.com/images/Auto.../jagxj1998.pdf
dba-one (03-14-2011)
From looking at the manual supplied (thank you again) This is what is listed for the source via the rear cig lighter:
ClGAR LIGHTER-REAR CATS, Z-WAY CIGAR LIGHTER, YELLOW REAR CENTER CONSOLE VENT
The wire that connect to the lighter is blue and white, not yellow. I've done things like this many times and it has always been straight forward. Am I being very dense here and missing something obvious?
That's all I've got. Good luck.
I can really sympathize with the "this should be so easy" sentiment.
Well, it is official! I am retarded. I took the car to a stereo shop and had them look at it. Two problems. The test light was a pile of crap. The second issue was that though my ground seemed good it was not. The instructions for the step down indicated it should be connected to a metal surface via a screw or bolt. The guy at the stereo shop said to skip that and just tap the ground for the cig lighter. I did so and all it well.
jagent
09-12-2015 09:10 AM
