1997 xjr transmission conversion questions/help
ok so heres the deal, if my car doesnt sell soon i want to swap in a different trans. id like to do a 5 or 6 speed manual trans swap. i dont want to buy a swap thats 5k. or mayb get the 5 speed auto out of a 98 n up xj. anyone done it cheaply or know what belhousing flywheel clutch speedo gearing i can use i can figure out drive shaft, pedal and most other stuff thanks im tryn to use a chevy manual trans or ?
Being a 1997 XJR, am I correct in assuming it has a 6 cylinder engine and fitted with a GM 480-E Transmission ( 4 speed)? I am only a DIY hack, but I would expect that you would have a hard time with the engine and transmission modules working together properly if you throw in a different transmission. I recently put a replacement W5A 580 Mercedes transmission in my 98 XJR, but that is the specification. I made sure it was from a Jaguar. Unless you have someone who can help you with the computer issues that will likely arise by putting in a non stock unit, you may be in for a difficult time.
If your transmission is done, why not find a stock replacement... or do you just want a manual shift unit?
I noticed you had no replies, so thought I would give you my opinion for what it is worth. Not meaning to rain on the parade, but it appears to be far from simple to modify or change from stock components in these cars. If you check the recent threads on differential swaps, it appears those are trouble as well, with the computer picking up unexpected ratio/speed results and subsequently throwing codes. In the old days, before electronic control of virtually everything, you could fabricate a fit that would probably work. Now there needs to be communication between components that sync properly.
On one of the posts about differentials, I read that the transmissions in the 308 cars could not be re-programmed to accept the new ratio from a different differential. It appears that the wheel sensors have a part to play by reporting expected speeds, so the car knows there is something amiss... and does not like it. If you can find someone to provide an all clear signal from the replacement unit to your existing control modules, maybe it can be done, but I highly doubt that it will be an easy transition. If you found a solution for that, you would just be left with the mechanical fabrication, which would not likely be a cake walk either.
Sounds like an interesting puzzle to work out... well beyond my scope. Maybe Avos can help you. His car seems far from stock!
aholbro1
08-05-2021 05:02 AM
Rlover
03-30-2016 10:04 PM
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
