1998 Engine Swap!!!
Guest
Posts: n/a
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
can someone help me, i have a 1998 xj vanden plas i blew my motor, a friend gave me his 2000 xj8 motor cause his wife totalled it in the rear, but my harness doesn't hook up right, & the cam advance locations are different, has anyone done this swap??? thanks for your help, kirk
Here is some more info:
https://www.jaguarforums.com/forum/s...d.php?p=177881
You have a AJ26 engine in the '98, and the '00 is a AJ27. You can use the AJ27 engine block easily, but you need to swap/reuse parts of the AJ26 which can be found in the link.
Rlover
03-30-2016 10:04 PM
