1998 Jag xj8 tilt motor replacement
Good Morning group, I am attempting to replace the tilt motor on the above mentioned car. I removed the old motor, but I am having a heck of a time getting the new unit installed. Any tips or advice is greatly appreciated. The alignment of the actuator into the motor coupling is my main problem. Do I have to drop the steering column to finish this project. Thank you for any advice.
I always plug the motor assy (mechanically disconnected from the column) into the car an run the motor UP until it stops.
Then 'hand-twirl' the column plastic male drive end to the max height and back off 1/4 to 1/2 turn.
Slide the plastic drive coupler together and level the motor assy until you can install the 2 screws. (I use a long 4mm ball end Allen 3/8" drive)
If you do not set the UP end point, the motor will not know where the upper limit is and try to drive past the mechanical stop.
stan61 (09-28-2020)
Thank you Motorcarman, you description will help me get this thing back together. One issue I was having was lining up the bracket for the wire connectors to be hung on, and trying to get the bolts started at the same time. but I will get back at it tomorrow, I'll have the whole day to tackle it. I have to say again, this Forum is a great way to get advice and information. thank you again.
Johnken
06-17-2015 05:08 PM
