Hello all, I've been a viewer for a while but I'm out of ideas on a car in my autoshop class. It's a 1998 jaguar XJ8 L. Me and a buddy convinced my teacher to let us bring it in and rebuild it, as it had been brought to the school with the engine tore down to the block due to the tensioners going out and it jumped timing, bending the valves. We have used mostly new parts in rebuilding this engine from the block up, have followed all sequences and torque patterns, and all the electrical is back in place with not a plug missing. The car will not start. We of course checked all the basic things, fuel spark and compression, but can't figure it out. To further iterate what we have tried, we cleaned out the gas tank and tested the fuel pump, as well as replaced the soft lines. All good. Fuel filter is not replaced, nor are the injectors (however we did spray them out) but there are no blockages throughout the lines. I don't know how much fuel pressure we have as the Schrader on the rail is missing the actual valve part, but we do have some amount of pressure as it sprays when the cap is off. Now spark, we have tested with test lights, pulling the coil packs and testing every single one individually, and all are firing. On top of that, they seem to be firing at TDC, as the spark occurs at the same time as air shoots out of a compression testing hose we attached to each cylinder. We tested every coil pack and every plug, all functional. We did test compression, as I am somewhat familiar with the bore wash condition that these nikasil blocks are prone too, and saw we had low compression. We opted to put oil down the cylinders, and the compression came up from about 80 lbs on average to about 140 on average. We have done that a few more times since throughout testing, but I haven't tested compression since then. I've checked timing once again, and it's all fine. I am simply at a loss. It will crank and crank, but never even try to run. With ether, given enough time, it will back fire one time on the second cylinder from the front on the passenger side, but nothing else. What am I missing? I know they are finicky cars but at the most basic level of engine requirements, it should run. Fuel (or ether), spark, and air. I'm at a loss, and even my teacher has no clue either. It's very disheartening considering how much time we put into this. Thanks in advance.
" Schrader on the rail is missing the actual valve part "
from my understanding the valve is not on all Jaguar V - 8s
Fuel pressure 43 psi at idle or not running engine
Change your main fuel filter and get rid of old fuel as can cause issues on starting
You may have put the cylinder into a " bore wash " condition
Hold gas pedal to the floor while cranking and the ECM know to not add fuel to reestablish oil from the bottom of the piston to recoat the cylinder walls
There is another similar condition of the early Jaguar V - 8s not having steel sleaves on the cylinder walls , the factory treatment ( nikasil ) to harden the bare aluminum bore did not hold up to real world sulfur in the fuel eating up the bore , low compression , TSB was to change whole engine to a AJ27 with steel sleaves
The fuel pump will run for 3 seconds only with key rotation , it will come back on when the CKPS sees engine rotation ( safety design )
The ignition is retarded back to 0 degrees TDC to aid starting then reverts to normal advanced angle and varies from there
There is a terminal post that gets compromised in the engine compartment that Motorcarman ( Bob ) would certainly know better about
Thank you for the replies, I will check inertia switch tomorrow. Does the inertia switch cut off fuel supply to the engine or does it stop it from running some other way? And on the same note, how likely could it be that my issue would be fuel pressure/filter or any other fuel related issue? Obviously not having fuel is a problem, but I'm a little baffled at the non-running state even with the use of ether.
That being the case, I'm inclined to believe the inertia switch is not the problem. Fuel pump is still operable, fuel is making its way to the engine. I put a light on the injector plugs before the summer and as I remember it, they all were receiving everything they needed to. That is not to say the injectors couldn't be bad though. Again, I have to stress that I'm not super worried about fuel supply at the moment due to having spark and not firing off of engine starting fluid. Whether or not I'm getting fuel like I should be, I would think it would still fire with ether.
So let me get this straight...Your first post indicates you have spark to the
cylinders. Later posts indicate you have fuel to the cylinders. The only
thing left is compression....or timing.
Randy, yes that would be the case. I have both spark and fuel. Timing being done the way it is, with the locking bars and the pin in the crankshaft, I struggle to believe timing would be the case. It does seem like my first bank maybe is a tooth or two off, which I don't know how I did but regardless, it's close enough that I think it should fire, even just backfiring or chugging or sputtering or something. On the idea that my compression was low, I have tried several of the borewash cures to no avail. Was running an average of 90lbs per cylinder, but was able to bring it up to about 140 on average, although it's been a while since then. I could do another compression test but I feel like I've oiled these cylinders an awful lot to not have enough compression still. Is it possible to have done timing 180 degrees off, even with the method used? The cams rotating at half of crank speed makes me wonder if the locking pin could've been put in on exhaust stroke instead. I don't know how feasible that is.
