1998 Jaguar XJR Crunching Brake/Suspension sound?
Crunching noise coming from rear tire after changing rotors, calipers, brake pads, and struts.
There Also seems to be a metal on metal sounds that happens consistently at low to medium speeds, it isn’t a constant sound but you can hear the scrape for a second when the tire makes a full rotation
Received 1,797 Likes
Is it normal for the brake pads to be loose or should they be firmly in place before installing onto rotor?
Check with whom you purchased your pads from. I originally bought from a national brand parts store and they gave me pads for Brembo calipers, mine are standard Jag, and those were way too thick. But it was all their system showed for mine, ...I had to go elsewhere. Check your rotors as well.
Pads should sit cleanly in the guides but snug, they need to move in and out without resistance. Like MS, I question lug tightness, but also check the wheel bearings, double check your work for bolt tightness and such. Did you change your brake fluid and if not, when was the last time it was done?
The pad seems to be able to move probably about a quarter of an inch freely, is that normal?
I hit all the Lug nuts with an impact again and one of them was loose so the rest probably were getting there. I think the aftermarket lug nuts aren’t gettin in deep enough so im going to purchase stock ones somewhere.
After tightening lug nuts the crunching noise did seem to go away but the uneven brake wear is still there.(I will get better pictures when I get back home)
I did not change brake fluid I just added to it when bleeding them since I had to replace calipers aswell. The fluid came out clean so i assume previous owner had done that at some point.
Aftermarket lug nuts generally aren't correct depth wise or recess and there are a couple variants from Jaguar with the variety of wheels available. You have the same Pentas I do so you should have 3/8" from the top of the nut to the top of the inner most part of the lug well. It dishes, so that was the easiest measuring point.
Do not use an impact on your lugs or you can expect to take off a stud. You can bring them snug with it, but torque them properly to 65-75 ft lbs for alloy wheels thereafter. If you use an impact on the proper jag lugs, they will begin to de-laminate because the finish cap is just a finish cover (not removable).
When you say you have a 1/4" of play, how do you mean, between the caliper and shoe before you pumped the cylinders back up or on your end guides? Your end guides should be fitting square in the holder. Do you have your old pads for comparison? It doesn't matter the part, you always do a comparison check before install.
Ran across this old thread in the "How To" Forum at the top of each MY, heavily suggest a review of it... https://www.jaguarforums.com/forum/x...ics-faq-35063/
Always use some kind hand tool to torq the wheels. Ipact gun will either put them too tight or leave them loose. It depeds in so many things wich way it is. Check the nuts with the old one. Put them against eatch other by the cones and you'll see is there any differences.
It is not un common to have weird wear patterns in discs after first couple of brakings. Pads aren't that straight. Then caliper sliding pins aren't bearings so there is always play. This is why there is so called brake in perioid.
If you are sure that there is no stuff between pads and discs and pads are correct way around. I'd say just drive it casually.
As for the brake pads where I circled in red is where I feel like has too much and compared to yours I’m certain there’s too much. I can’t get a picture of mine at the moment since I’m out of state but I will get a picture asap.
You should have these lugs CAC45472 (2") for your Penta wheels... https://www.welshent.com/Search?make...=wheel+lug+nut
You shouldn't have any play in that area of your pads. It's been awhile and I'm on vacation, but I'm almost 100% these are the correct pads.
JackyT
05-24-2016 11:19 AM
