1998 Jaguar XJR Driver Side Door Controls
I just replaced the driver door control panel since it wasn’t working and when I had first plugged it in everything was working fine, so I unplugged it to fit it into the door but when I plugged it back in none of the buttons work except the rear passenger window button which got rerouted to the driver window somehow.
Jhartz (06-18-2024)
Good radiator shop can fix it but for now remove the assembly and sand the area let dry then use JB weld high heat let cure for 48h i believe it will stop the leak I had similar leak and jb stopped the leak for 6 months then in a very hot day in summer it leak again I got used radiator in good condition however I had to take it to shop and clean it and replace the transmission fluid cooler because it rust over time and anytime can mix coolant and ATF which is something you don't want . Check the market here you will find used radiator
Deany Boy
02-06-2018 02:32 PM
jimlombardi
12-15-2012 11:12 AM
Hill2302
11-05-2010 09:22 PM
