1998 timing chain tensioner
Someone posted on the forums here that you could put a small mirror in the oil filler hole in the cam cover to view the tensioner and if you could see "red" at the front end of the engine inside that meant that the tensioners had not been replaced.
I tried it, but could not see anything. I also know that the plastic sliders on even the new tensioners turn red with age, so this may not be a valid way of evaluating the replacement.
So, I think you are going to have to pull at least one cover to find out.
I have also heard about factory mechanics replacing only one tensioner and not both, so you should check both sides.
It's not a difficult or time consuming job, just make sure you replace the cam cover gaskets when you are done.
Vector
Vector
RoyLittle0
05-25-2023 02:38 AM
