1998 Transmission Cooler Lines
It would be most helpful if we knew what you were working on. XJ8 or XJR. You can use the User CP button at the top and add the info to your signature.
If you have an XJ8 then SNG Barratt a forum sponsor has both hoses in stock. For the XJR they have the supply lines but only one return in stock depending on the VIN.
Follow this link to the parts page : https://www.sngbarratt.com/us/#!/Eng.../43/all/1/10/1
You can also download the catalog for free.
I had success with using a short piece of oil resistant hose with an ID the same as the OD of the aluminum cooler line. I split the hose, coated the line and the inside of the hose with RTV used for sealing oil pans to blocks.
I placed the line over the damaged area and secured it with plastic 'zip-ties'.
Let it cure overnite and it held the low pressure oil just fine.
Bend all the pipes/hoses so they no longer contact one another.
bob
bob
Lady Penelope (05-10-2018)
He is a link to my solution when I had the problem. I used a steel braided line with AN fittings.
https://www.jaguarforums.com/forum/x...ck-fix-171463/
Stu 1986
12-21-2011 08:15 PM
ragtop
09-07-2011 09:14 PM
jaguar 20
16
08-18-2010 08:54 PM
