1998 xj8
I just bought my xj8 at an auction, and i am trying to work out the bugs. it has 99300 miles on it i've changed the coolant sensor already, but when i start it pu the engine seems to be a bit loud, like a tapping .also when driving sometimes i can see the rpm needle dip abit and i can hear the engine do the same. is this the plugs. i'm no mechanic.
Let's start slowly.
Is the check engine light on? If so, what codes?
What maintenance history do you have? Without a history we need to see the cam chain tensioners.
At 99k miles it is scheduled for plug change. Put that on your list.
I would add a MAFS, throttle body and breather hose cleaning.
Rummage through the posts on the XK8/R FAQ sticky at:
https://www.jaguarforums.com/forum/s...ad.php?t=29800
for more information than you ever wanted.
Without a history of maintenance I would also do the fuel filter and the air filter.
Please report feed back from the above and we will go from there.
WTB[SouthEast]: 2000 XJR door seal
moff1959
09-26-2015 05:35 PM
