1998 XJ8 Jag with issues
Ok I put a new battery and cleaned all connections. Bulk connector was clean, also cleaned connections on fuse boxes on drivers side. Still nothing when I turn the key, I wonder if there is a nutral safty switch or something in the gear shifter. if low power was getting to the starter I think I should get a click or something. Crawling under now to have someone turn key while I put a test light on the low power wire. Man that starter looks tough to get out...
