1998 xj8 no start
Change The air filter; clean the throttle bore, carefully; check underneath the throttle body to make sure that all the vacuum lines are intact. Crank the engine to determine whether the bearings are seized on any of the assessory drive belts. Reset the CEL. Make sure all fittings from the air filtet to throttle are tight. Clean the MAF sensor.
Rlover
03-30-2016 10:04 PM
