1998 xj8 for sale
Old 04-26-2014 | 12:36 AM
MarylaLuna's Avatar
Default 1998 xj8 for sale
$2900
http://inlandempire.craigslist.org/cto/4431634668.html
What ya think?
Old 04-26-2014 | 03:05 AM
Are you considering buying it?
Old 04-26-2014 | 07:59 AM
jimlombardi's Avatar
Looks like a good deal.
This photo shows its picnic table open in the rear seating area:
Here is weblink to some information on it based on its vin (SAJKX6245WC842218):
1998 Jaguar XJ Vanden Plas VIN SAJKX6245WC842218 - Free Jaguar XJ VIN Decoder
If you are really interested in buying it, you need to know its repair and maintenance history, also any DTC codes flagged issues (like abs, trac, cruise, P codes,,etc).
A VDP model and is one of the top of line XJ models.
Jim Lombardi
Old 04-26-2014 | 10:22 AM
mcm97's Avatar
Jaguar/ newer
Low risk, potentially high reward. If nothing else, you could part it and scrap the carcass
Old 04-26-2014 | 11:12 AM
MarylaLuna
Are you looking to buy it or is it your car you are trying to sell?
Jim Lombardi
Old 04-26-2014 | 07:27 PM
MarylaLuna's Avatar
Default I am looking to buy, seems to be at good price, what do u think?
Originally Posted by jimlombardi
MarylaLuna
Jim Lombardi
Thanks Jim..,
Old 04-26-2014 | 07:51 PM
What I am thinking that if I lived close enough to Riverside Calif, then I would be looking to buy that 1998 Jaguar VDP if it has records and receipts (showing maintenance and repairs done).
I would also have inspected before I buy to see if has any body repairs (past accidents) and other major repairs (such as timing chain tensioners, throttle body, ABS module, Security Control module, Brake Pedal switch, Instrument Cluster, broken wiring in Left hinge trunk area, Door check arms, little or no heat when you need it- clogged octopus hose unit and broken aux heater pump).
I wonder if I forgotten any other things that usually go wrong with the 1998 to 2003 XJ models.
Sounds like the Transmission has been rebuilt recently (another known issue with XJ X308 models) except the XJR.
You should also have a mechanic who has proper scanner to view DTC codes for all the Jaguar systems (Engine, ABS, Body, Security, etc).
Jim Lombardi
MarylaLuna (04-28-2014)
Old 04-26-2014 | 10:11 PM
MarylaLuna's Avatar
Jim!
I called the owner, going to look at it tmrw then take it to mechanic during the week. I will look for jag mechanic in town.
I will ask about records tmrw.
Thanks,
Old 04-26-2014 | 10:25 PM
MarylaLuna's Avatar
Default Low risk
Originally Posted by mcm97
Jaguar/ newer
Thx for your valuable opinion!
Old 04-27-2014 | 07:28 PM
MarylaLuna's Avatar
Default X308 update! Next!!!!
Owner turned ignition, the engine was knocking, the serpentine belt shredded immediately. He said he just replaced the water pump, there were two bottles of antifreeze in the trunk. Stabilizer warning light on and abs light on
Old 04-27-2014 | 07:55 PM
Well, it sounds like that car was not in the condition needed to sell right now.
Knocking engine means that maybe the knock sensor needs replacement.
ABS & Stability probably means ABS module repair, or Wheel Speed Sensors needs cleaning or some thing else.
The car probably has a lot of issues that are unknown.
Jim Lombardi
Old 04-27-2014 | 08:16 PM
MarylaLuna's Avatar
Default Not to be
Jim Lombardi[/QUOTE]
Plus he bought it at auction a year ago, parted out a 2000 to fix it and never transferred title into his name.
Humorous actually. Grateful it broke before I test drove it or bought it.
Old 04-27-2014 | 09:47 PM
aholbro1's Avatar
Not to worry. Keep looking, you'll find a sweet one.
Old 04-28-2014 | 05:14 PM
MarylaLuna's Avatar
Jim Lombardi
There is truly a knock sensor?
I am easy to tease, since I tend to be a literal person, but that just seems so silly!
LOL
Old 04-28-2014 | 06:34 PM
RJ237's Avatar
The knocking sound was more likely a bad rod or crankshaft bearing. Knock sensors prevent preignition of the fuel mixture when lower octane fuel is used or engine is laboring at low speed. Preignition sounds like marbles bouncing inside engine. Failure of a knock sensor could certainly cause it, but bearing knock is more of a metallic sound, like hitting with a hammer.
Old 04-28-2014 | 07:40 PM
aholbro1's Avatar
Pardon me, but I speak knock and would be happy to translate: BOTH sounds are screaming "RUN AWAY, RUN AWAY!!!" at potential used car buyers...that is, unless you've just had your existing same-model rear-ended but it has a sweet engine of like kind and you fancy doing the swap yourself.....
Old 04-28-2014 | 07:51 PM
Sorry, I was joking a little, and yes the knock you hear could have been pre-ignition due to using low octane gas, or timing chain tensioners starting to fail, or ????.
There are 2 knock sensors on XJ X308 engine - look at this other thread (also see its post 22):
https://www.jaguarforums.com/forum/x...t-1-2-a-76815/
Jim Lombardi
Old 04-28-2014 | 10:49 PM
WaterDragon's Avatar
The price alone was saying something was seriously wrong.
"I speak knock" that had me laugh out loud.
aholbro1 (04-28-2014)
Old 04-28-2014 | 10:57 PM
aholbro1's Avatar
Just trying to channel June Cleaver from one of the "Airplane" movies...
Old 04-28-2014 | 11:38 PM
MarylaLuna's Avatar
Default Love it!
Exactly/ marbles,
Airplane... Yep I was laughing all the way home and kissing my 03 Element that only needs regular maintenance!
Quick Reply: 1998 xj8 for sale
