1998 xj8 took ignition from a parts car if I take Key transponder module and put it i
Now that we've determined you have a 1998 XJ8, I've moved you threads from XK8/XKR (X100) forum to XJ8/XJR (X308) forum. This is the place to post technical questions about your model.
A MATCHING Key, Key Transponder Coil and Key Transponder Module are essential for it to start BUT I think the SCLM (Security and Locking Module) could also have a part to play.
Need to know if the problem is that the car will not crank or it will crank but will not start. A no crank could be a number of things and need to know what you have going on. Do you have fuel and spark? This link should help to guide you along.
Link to No Start JagRepair.com - Jaguar Repair Information Resource
I put transponder module from parts car which matched ignition switch and I have the key exciter ring also but never installed it.NOT SURE HOW?? the one Key ring is still hooked up but didnt realize its like an antenna that reads my key?ITS A NO CRANK I HEAR A SINGLE CLICK NEAR PASSENGER side under dash when I try to start it. Everything works other than that lights radio windshield wipers seat heater and steering whell movement so its definitely a no crank!!
Djmcmann
02-09-2021 07:11 AM
jagsim
11-22-2018 12:22 AM
