1998 xj8 trunk will not open
Guest
Posts: n/a
1. Trunk does not open by hitting the trunk release by the steering wheel
2. Trunk does not open by hitting trunk release on key fob
3. Trunk does not open by hitting trunk circle button on trunk
The only way it will open is by key in the trunk
I checked the fuse F-10 and it was good.
There is no noise when I hittry the methods of 1-3 above. Is it thetrunkmotor? Also the light in the trunk does not turn on but the fuel flap lock stilllocks and releases.
Wiring bundle in trunk, at passenger side hinge, commonly gets a break in one or more of the wires where the bundle flexes when opening and closing the trunk. Easy fix - I suggest you leave a bit more slack than the factory did, when you fix it.
________
1999 XJR
________
1999 XJR
