1998 xj8 wiper problems
The issue I am having is the wipers only work on high. the washer does work. No blown fuses and I wsapped the relays and no changes. I unplugged the motor and I can see ground and positive on the plug side. I do get ground and positive on different pins when changing from slow to delay to high. So it appears there is no issue with the staulk mount,relays or fuses. I wanna be sure though. Does anyone know what the five wires do on the motor plug. It appears the 2 black ones stay on ground. The blue I believe swiches to 12 volts when the wipers are on high and I think the red/yellow is constant 12 volts. There is also a red wire not sure what it does. I just need to know what to hook up these 5 wires to so I can test the slow speed as well as the faster speed and I assume I wont be able to bench test the delay. Thanks
Rlover
03-30-2016 10:04 PM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
