1998 XJ8 won't start
. . . and all you are going to tell us is that it won't start? Does it turn over (crank) when you turn the key? Do the lights all come on when you turn the key? You might have a dead or weak battery.
If it cranks, push the throttle all the way to the floor and begin to crank; if it is flooded or has bore wash, it may start once it clears out and gets oil in the cylinder walls to give you compression. Search for bore wash.
Do you have fuel at the rail?
What codes are you showing?
Your key may have to be reprogrammed. Does it start with one of the other keys?
Don B (07-29-2020)
Received 12,917 Likes
AD2014 (08-06-2020)
George702
10-15-2012 08:26 AM
