The 1998 XJR 4.0 to 4.2 engine swap thread !!!:)
#41
Agree with the damper, better the 4.2 one then a custom larger pulley, but have my reservations with the 7 rib belt (would probably try it myself t be honest).
You can still use the front conver, but I cant see why you want to use the lower bed plate, especialy not now with the issue. Make sure it fits perfeclty to avoid belt alignement issues.
Cobra pulley will not work, its a very different one, iirc the upper is about 2.93" or so.
#42
What do you call the bed plate? I'm confused.
![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
Also, what size are the available SC pulleys for Jags?
#44
#45
Honestly I can't believe how much cleaner the '04 engine is. There is no sludge on anything. The place I bought it from told me 70K miles on it, but I seriously doubt that they had an idea as the car had a cabin fire. I'll see if I can dig up a VIN from it and run a carfax.
NEW:
![](https://a4.sphotos.ak.fbcdn.net/hphotos-ak-ash4/316170_10150337210728988_818348987_7941859_1948892976_n.jpg)
OLD:
![](https://a6.sphotos.ak.fbcdn.net/hphotos-ak-ash4/299814_10150337210648988_818348987_7941858_792172035_n.jpg)
![](https://a3.sphotos.ak.fbcdn.net/hphotos-ak-snc7/309566_10150337210518988_818348987_7941856_143003977_n.jpg)
BTW the alternator seems to fit with no modifications:
NEW:
OLD:
![](https://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash4/316956_10150337210413988_818348987_7941855_1634597558_n.jpg)
#46
So, I just want to point out. Research, read, read and read more. Study AVOS's Reference 20 times before you start. People supposedly only retain 20% of the knowledge...now I know that it's a fact.
I almost had a panic attack today
There I am trimming the front cover to make brackets fit and I start to disassemble the bottom sump and pickup....
Well, I take it off and I notice that the oil pump is totally different![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
My first thought was.....holly molly, I gotta take the whole front cover off and screw with the timing chains ( well I see why they are better on the '04, the '98 look like bicycle chains, I'll snap a pic tomorrow) and get a new pump....than I started thinking if the '98 pump would be big enough to sustain the jets....anyway I ended up with a headache from thinking and decided to re-read things over again....
Well after a few minutes it finally saturated into me:
So, now I'm relieved that I can leave the front alone....(and keep the big pulley
and the oil pump) but now I have to figure our how to mod the old lower sump. Also, does the pickup need to be modified?
-The oil pickup is different with the 4.2 oil pump; you need to modify the original sump to allow space for the new pickup. This is important as the 4.2 engine uses piston oil jets to cool down the system (This is also why the 4.2 blocks do have not the issue with short running that washes away the oil film…).
#47
#48
I was initially speculating about keeping the 4.2 one, but you made a good point about the filter location and I also don't want to go through the trouble of reworking the oil cooler lines. So, I will be using the one from the 4.0.
Can you give me some advice on how to make it work with the 4.2 oil pickup/pump?
Thanks,
Adam
#49
#51
#53
#54
#55
#57
Love it Adam, when do you think it'll be back in?
One thing to mention, the later AJ27 SC unit has the same oil pump, pickup and sump assy as the 4.2 (from engine number 0108130000 August 13 2001)
Could using just crank and con rods on these later 4.0 make them the same thing as the early 4.2, or is there more to it than a stroked crank and thinner con rods?
#58
#59
OK, so I started to bolt up the top end today.....and I run into a problem...
The camshaft position sensor on the driver's side of the AJ34 heads interfeers with the fuel rails, how do I get around this?
![](https://a6.sphotos.ak.fbcdn.net/hphotos-ak-ash4/309155_10150339882643988_818348987_7960656_585196591_n.jpg)
As you can see here, the rail will not go in with the sensor in place and we can forget about the fuel connector:
![](https://a4.sphotos.ak.fbcdn.net/hphotos-ak-ash4/299767_10150339882748988_818348987_7960657_2082796562_n.jpg)
