1998 xjr crankshaft position sensor replacement, any tricks?
I have the no start issue and code once the car warms up so I ordered both the camshaft and crankshaft position sensors. How the F are you supposed to replace the crank sensor ? Anyone have any trick other than taking the motor out?
The later sensor that has the connector at the sensor itself is electronically compatible so you could splice a connector from an AJ27 salvage car. I have done this as the connector for the AJ26 is located at the rear area of A/C compressor.
I even have a substitute 'link harness' and later sensor I made for diagnostic purposes.
I personally have never seen a faulty CKPS but DTCs and wiring problems sometimes require substitution of parts to eliminate the possibility.
bob
bob
adam699 (02-21-2016)
bob
bob
It was an intermittent problem so time will tell. Usually it wouldn't want to start once warmed up. Yesterday I tried to recreate the condition, but it kept running. I'm not able to drive it as I have the car apart for some rust repair and paint.
Isaiah8190
02-18-2016 03:58 PM
car5car
02-17-2016 02:35 AM
