1998 XJR - problems fitting a 2001 XJR engine
My name is Kamal.Help please.
I have jaguar XJR X308 of 1998. I had a knock in the motor. I decided to change the engine for the engine of 2001. When replacing the engine I found a difference in camshaft sensors. In 1998 there was one sensor, and in 2001 their two. As to install me the motor of 2001 on my jaguar xjr x308 of 1998 with one sensor. Whether I will be able to start the motor of 2001 with conducting, both the control package and the sensor of 1998.
Sorry for my English
I believe you need to swap the pick-up on the cam and use the 98 parts.
Someone else should confirm.
Edit: Here's a thread on it https://www.jaguarforums.com/forum/x...-aj27s-110565/
XKR_Ben
11-13-2015 10:31 AM
