1998 xk8 abs traction control ,stability control warning lights.
New battery , fuses okay , measured sensor resistance at abs plug and reading 1.100 k ohms on all four wheels. removed abs unit and drilled 2 holes where the pump connections are and these connections have checked out okay with a meter.
Be most grateful for any help please
JimC64
03-02-2015 08:07 PM
