1999 Vanden Plas Resets After Battery Replacement
Hello Jag Nation,
I just completed my first battery replacement on my 1999 Vanden Plas. Can anyone provide or direct me to information on all required resets, etc, after battery replacement. Also, are there any Jag idiosyncrasies I need to be aware of?
Thanks for your considerations
Jagjust4me
Jagjust4me
You should retain the pre-sets of the radio, but you will need to re-set the bass/treble settings for the radio, cassette & CD player (they each have to be set individually).
The seat/mirrors/steering wheel memory settings will be lost and have to be reset.
As per neurojags' list, the clock will need to be re-set.
The stock battery is a flooded wet cell that needs to be vented. Upgrading to an AGM is well worth it as they handle a deeper discharge much better. With all the electrical glitches these cars have from batteries not being up to par, I figured it was a good idea even tho my flooded interstate is still 100%.
The Platinum is one beast of a battery @ $200+. 1050CA, 900CCA, 180 reserve capacity, 95 amp hours
Most AGMs I've ever seen don't have a vent. The Die Hard Platinum I replaced the wet cell in the Jag with DID have one. Probably because of what it's replacing? Idk. But since it had one and the hose was there, I hooked it up. No reason not too. If it didn't have one, I wouldn't worry about it tho.
ragman1171
05-24-2016 11:30 PM
