I have a problem.when putting car in drive the car is slow to move off.after moving off gears are fine.could it just be transmission fliud or could the transmission need replacing
I have moved your post from the forum for the X350 to the forum for the X308, which is the Jaguar factory project code for your 1998 XJ8. Here you will find knowledgeable owners of similar cars.
