1999 xj8 3.2
If you use a site like Tire Size Calculator
you will see a difference of about -1 mph at 60mph. The 17 " tires are smaller in height than the 16 " so you would be doing about 59 mph (59.3 to be exact ) instead of 60mph.
I do not know if they will fit or rub or any other problems you might run into, just ran the numbers for you.
Heliwilly (07-25-2015)
