1999 XJ8 a/c lines
It's the upper hose and is under pressure. It is part metal with a short rubber hose between the two ends. The jag website shows it discontinued. Tried Moss Motors as well no luck. Ebay shows some, but all are used and not sure if they would be leak free....no returns for those parts offered.
Over here I'd go somewhere like Pirtek who make up hoses for hydraulics etc. The chances are the metal sections are fine & the crimp or rubber bit has failed. They could replace that onto the original hard sections.
You must have something similar over there, but I wouldn't have a clue on company names.
Thanks, went there, but they don't do A/C lines anymore. They referred me to Alternative Hoses LLC. They will teapot, test and guarantee repair!
"About $110" per hose and 1 turnaound... thanks for the lead. I will post results. Alternatve Hoses LLC appears to be franchise company natio wide.
Xanzar
06-04-2020 10:14 PM
