1999 XJ8 code P0358 won't start
Hi all,
My beautiful Xj8 Sport wont start.
Battery is charged and has the right voltage when testing with a voltmeter.
Have tested the starter, flywheel is spinning freely.
Would a failed coil cause the ECU to cut voltage to all coils ???
Your help is appreciated (in advance).
Tony
Tony
Spinning freely suggest you may have bore wash. Did you shut the engine off after running briefly, as in just moving the car over? Another possibility is fuel pump failure. Also see below:
https://www.jaguarforums.com/forum/g...d-first-30792/
Hi,
I did quickly move the car across my parking area (only took less than a minute). Sounds like it could be borewash. Will try the solution for that.
My previous loves
1977 XJ6
1985 XJS
My future loves
2001 XKR
My previous loves
1977 XJ6
1985 XJS
My future loves
2001 XKR
Last edited by TonyXJ8; 12-27-2016 at 02:32 AM. Reason: More info about my car likes (and previous ownership).
FS[NorthWest]: 1999 XJ8 for sale
motorhommie
10-19-2016 02:28 PM
Jeff DeVere
10-13-2016 07:00 AM
