1999 xj8 massive battery drain
Hi, have a pretty big problem with a parasic battery drain, in fact huge!!, drain test shows 6.96AMPS!!!, disconnected alternator down to 4.56AMPS so still have a massive drain, had alternator bench tested and its ok, also shows ECU is still powered up when key out of ignition. HELP any ideas? Cheers Mark
thetruthc32
08-16-2007 08:03 AM
