1999 XJ8 will not always start please help!
My 99 xj8 just recently began randomly not starting. Prior to this I never had any issues with it. There is really no telling when it will start. More often then not it doesn't start. When I turn the key to start it all the lights and sounds work properly, but the engine does not crank at all it just does absolutely nothing. The car typically start after sitting for long periods of time and usually will only start late at night when the temperature outside is very cold. It began not starting only a few times a week but has gradually gotten worse over time. Now the car will only start every 2-4 days, and I'm lucky to get it to start more then once. Has anyone else had this problem? My first guess is the transponder, Bc sometimes I can hold the key in the start position for 6-10 seconds and it will start. PLEASE HELP!!!!!
Thanks for the help guys! I tried moving the shifter while starting the car and nothing happened so I dont think its a neutral safety switch, the battery is good and all the lights and sounds work so i dont think the terminals or battery connections are the problem. Man this is frustrating!!! Could it be my transponder, or ignition lock cylinder?
The other option is to swap your relays with like relays. Often the reseating of the relay will eliminate the problem but if it is a relay you only moved your problem to another location. If this does not fix the problem then you should look into replacing the exciter ring at the ignition switch.
This oneline on the car should help. http://jagrepair.com/images/AutoRepa.../jagxj1999.pdf
jagwah (02-27-2012)
Ya I don't want to move the problem to some place else, I need to get the problem fixed to sell the car. One thing I thought of... I had to have a breathalizer interlock device in the car for several months, but after it was removed the car worked fine. Idk if this may be related to the issues I'm having.
Wolfy
05-28-2024 08:06 AM
Jaguar Forums Editor
Jaguar Press release
09-03-2015 09:38 AM
