1999 xj8 will not start
I needs help please. My 99 xj8 crank over well, but will not start up 95% of the time. When it want to start one crank start up and run normal. I can driver normal as soon I turn it off let it park for about 5-10 minutes. It will not start agian. Had good fuel pressure but no spark, injector only has one blink. I replace crank sensor, try with other ECM from recycle yark with the same part # on it it still the same. I check all the relay are good. I order Mongoose JLR Blue body from china web site hoping a can get it to work and try to follow TSB S479 to reflash ECM. The chinee clone Mongoose JLR will not load up the driver and connecting to PC or Car Module. Any help I can get I very appreciate.
Thank you.
Thank you.
Wolfy
05-28-2024 08:06 AM
Jaguar Forums Editor
Jaguar Press release
09-03-2015 09:38 AM
