1999 xjr door trim removal
Hi guys
I need to remove the door trim of one of the rear doors in order to find out what causes that bloody RATTLE!! Sorry, its starting to get to me.
I dont usually do these things myself but this rattle has made it personal!
Can anyone list out step by step instructions for getting the trim off, and then on again. Id be very grateful.
RE: 1999 xjr door trim removal
usually the wood that squeeks and rattles.. 1st remove the screw cover in the handle then screw.. then black handle surround . then the wood needs to be pryed with something plastic away from the panel.. only the part that is near the rod..only! then when wood is loose slide the wood away from the handle.. then one screw is hidden2/3 down .. look and you will see it. then door shud come off.. once off there is a big plastic clip that needs to be removed and placed back in the door skin before the panel goes on.. i wud remove wood 1st and see if rattle goes away.. when you install the wood.. slide it then push it in the door.
dsetter (01-17-2011)
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
