1999 XJR - it's too dark in the cabin...
Just bought a 99 XJR from a family member and when I was driving at night I noticed none of the center console buttons light up. The instruments do have a light and the radio and climate control also have a backlight, but they do not dim when I play with the dimmer switch. I checked all the fuses and they are all good. I'm thinking it could be an issue with the dimmer switch. I would be surprised if the bulbs for most of the center console and the clock went out at the same-ish time. Any thoughts?
Just put a disco ball behind the sunroof if it’s too dark in there.
The instrument cluster (speedo, tach, etc) most likely needs new bulbs. 22 year old cars need love. It’s not hard to pull the cluster out to change the bulbs. Just move the steering wheel towards you as far as possible and tilt it down as far as possible before you start taking the cluster out. There’s write ups that detailed this procedure when you search for it.
sdblacksheep (10-21-2021)
Edited to add: those little bulbs are everywhere in the car - Besides the instrument panels, I replaced them in the window switches at all four doors, maybe even the ash tray area if I remember right. They were almost all burned out in my car. The interior looks very nice when all the bulbs are working.
Yes. I replaced almost all of mine when I restored my 98 XJR because most of them were burned out. Many of those bulbs have a blue rubbery "filter" that covers the bulbs. You'll want to save those. They slide off and you can reuse them on the new bulbs. Replacement bulbs are easy to find, but it might be hard to find the blue rubber filters.
hisport
04-13-2016 09:39 AM
