1999 XJR and Nikasil issue
Old 05-20-2007, 11:16 AM
Envy337's Avatar
Default RE: 1999 XJR and Nikasil issue
It's going to break down.
If you want the car that much, invest in a rebuilt engine.
Old 05-20-2007, 05:18 PM
Cadillac's Avatar
As far as I know ,nikasilsuffered freeengines have the last 6 digits of the chassis number begins with an F, for example F67894.
Old 05-21-2007, 11:56 AM
bigdreams05's Avatar
Don't get it. It will break down. Look at about 4K for a rebuild!
Old 05-21-2007, 05:33 PM
ken@britishparts.com's Avatar
Timing tensioner failures have caused far more problems then the Nikasil issue. I would be far more concerned about rattle at start up. I've seen only one engine fail due to Nikasil.
Envy337's Avatar
Labor is around 19 hours.
It wont die on your right away.
Today i had an '00 XK-8 that needed a new engine. Only had 41K miles.
Old 05-21-2007, 05:35 PM
Envy337's Avatar
ORIGINAL: ken@britishparts.com
I've seen almost a dozen this year.
Old 05-22-2007, 09:23 PM
FL XJR's Avatar
ORIGINAL: Don.Key
...It is a European car and was driven in Europe....
Since the primary component causing the cylinder wall coating to fail is the sulfer content of gasoline, the question here is, what has been the sulfer content of petrol in Europe. If it has been run with low sulfer fuel from day one, it may not be so bad. However, you are still running a risk. I would at LEAST get a compression and leakdown test on the cylinders to see how each onecompares to factory specs. You also have to consider re-sale. YOU may be convinced the car is fine - and in fact, you may get some great use out of it. However, when you go to sell it, someone will likely have the same concerns as you, except the car will be older with even more miles on it. For what it costs to put a rebuilt or new engine in it, couldnt you find a newer car (2000 model year or newer) with low miles in similar condition? I opted for a 2000 with a little bit of a warranty leftversus a '99 witheven lowermilesbut no warranty but in better kept condition and full Borla exhaust. I rest easier knowing that I won't have a Nikasil issue, thoughI spent a little $$ to have the wheels refinished and a crack in the wood redone. (cheaper than replacingan engine )
JarodL
03-07-2024 01:39 AM
Forcedair1
05-14-2023 03:28 PM
Rlover
03-30-2016 10:04 PM
XJsc-guy
09-25-2015 11:09 AM
Quick Reply: 1999 XJR and Nikasil issue
