1999 XJR Scanner, code reader
Having recently purchased a one owner 1999 XJR with 64,000 miles I am in the process of getting all the faults sorted. I have replaced the front Shocks and towers, next job is rear shocks. I have several other issues.
I would like to find a Scanner/code reader that can identify the SRS fault and ABS and traction control faults I have. I have purchased two and ended up returning both. Help!
I have a iCarsoft i930 scanner that seems to read all the codes on my Jaguar XJR and VDPs. This version only works with Jaguars and Land Rovers; which is not a problem for me since I have another generic scanner when I fool with other cars for pals.
It reads all the modules that are present or that report to the ECU. Even the seat controllers!
Here's a link to the manufacturers page with details. Sort of pricey but you can find it a bit less at the usual purchasing portals. At least it will work perfectly with our old cars....
https://www.icarsoft.com/Product/s-3...verjaguar.html
Sean B (08-16-2022)
