1999 xjr supercharger....question
My father and I were talking about whether the supercharger on gets better gas mileage or not. Theres a button to press on the center console to turn on/off the supercharger. Anyone know the answer? More air is good for gas mileage right? And you dont have to press the pedal as much you just barely touch it and it hauls *** and then you can let go and coast.
There is no switch to turn the blower on or off?? The supercharger is belt driven by the crank. What switch are you referring to? There is one for the cruise control and another one for Sport mode shifting for the transmission located in the center console.
The supercharger is going to consume more gas than a normally aspirated model. Power is needed to drive the blower. More air means more gas. Air-fuel ratios remain more or less constant so the more air you force into the engine via a blower (supercharger or turbo) the more fuel it's going to consume.
Thanks for answering the question tho. Your answer makes sense
what does the "supercharger on/off" button look like, and where exactly is it? does the supercharger have a clutch similar to an A/C compressor? I would think it needs to operate full time or it would restrict the fuel/air mixture to the engine. I have a 1999 XJR also, so it would be good to know. Margo
There is no button to switch the supercharger on and off the button your are talking about is the "S" or Sport switch that just changes the shift pattern of the trans
There is no way to turn the supercharger on and off without removing the belt
Having the "S" button off will increase gas mileage
thank you so much for clearing taht up for me
I feel stupid, but its okay Iv only owned this thing for like 4 days...
Its not my fault I believed that, the previous owner told me that.
Welcome to the forum
Also remember, if you need parts or work done, these guys deserve the business any time it's possible to give it to them. I have yet to actually buy a part for my XJR, but when I do, I'll definately be hitting them up.
FS[SouthWest]: Parting out 1999 Vanden Plas
Brewmonkey
21
05-30-2016 12:50 AM
BlacXJRcat
09-25-2015 06:43 PM
Brewmonkey
09-20-2015 01:43 AM
Ipc838
09-13-2015 03:27 PM
