1999 xk8 Trans problems
Hi Guys im New to the forum! My 1999 Xk8 its goin into restricted performance, transmission fault! Barely moves wen trans fault lights come on! But it only does it sometimes! I have took it to 3 diff shops that says its a sensor and they don't know exactly witch 1! It can't be the trans its self Because I can start off in neutral and go straight to drive and it drives fine! I picked it up from the trans shop today and it drove perfect!
If we're talking about ZF tranny (NA engine) then it can be a famous transmission issue with a valve body and an A-drum failure. Soon enough you'll have only 5th gear left. Check fault codes, if there's "incorrect gear ratio" codes present - prepare to spend some money on a transmission. Sorry.
Welcome to the forum. When you have time please visit the new member area and introduce yourself. Just click on the link:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
It certainly sounds like your transmission may be at fault, but before writing it off go to one of the automotive stores and have the battery load tested. A weak battery can cause a number of incorrect codes and apparent faults.
99xk8guy
06-05-2023 06:28 AM
