1999xjr power steering pump removal instructions
You've to remove the pulley off the front first. Use the belt tension to undo the 3x m8 bolts.
Once the pulley is off, you can then remove the single long bolt m8x80mm, slide it out and remove the pump. Then disconnect the hoses and drain the fluid.
Install the hoses onto the new pump.
Bolt the pump to the bracket, then install the pulley and reconnect the accessory belt.
Sounds simple, 4 bolts, but it's a bit tight down there, maybe easier to go at it from underneath.
Hope this helps.
Hope this helps.
xj8 detroit (09-26-2020)
oldjaglover (03-02-2022)
scooterforever
05-02-2023 12:18 AM
kr98664
03-20-2019 03:21 PM
