2 new error codes p1000 and p0455
+1 on the P1000 / P1111
Nothing to worry about unless you must have P1111 to pass inspection. The checks will complete themselves as you drive or you can force them faster by going through a number of 'Drive Cycles'.
P0455 : EVAP system leak detected (large)
Possible Causes
Fuel cap off
Fuel cap seal defective
Fuel Tank leak
EVAP system leak - canister or pipework damage
EVAP valve to engine purge pipe blocked / damaged / leaking
EVAP valve operating vacuum hose leak / blockage
EVAP valve failure
EVAP valve to ECM circuit open / short / high resistance
Possible Causes
Fuel cap off
Fuel Tank leak
EVAP valve failure
KarimPA
09-27-2015 08:46 AM
