2 Questions: Garage Door and touch up paint?
1) Anyone had any trouble with the garage door opener. It blinks like it should but does not seem to work. Its says the outer buttons reset it, do they mean 1 & 4 or 3 & 4. Anyone struggle with this let me know please.
2) where can I get touch up paint for little stone chips on the bumper?
your garage door opener may having a rolling code feature. if this is the case, you need to first program the overhead remote, then there will be a learn button on the opener, press it. the opener should start blinking, then press the programmed button on the overhead unit, should work then
On my 2001 the 1 and 4 buttons clear the memory. I found my Owner's Manual Addendum and IT SHOWS the proper way to program. The original manual is wrong/incomplete.
WinterJag
16
10-09-2015 07:49 PM
