2 sizes for the front sway bar links
I just replaced my front sway bar links (2nd time) and found the first set that I had installed are about 1" shorter than the new links. I dug out the ones that were on the car when I got it and they are also the longer ones. The brand new links are URO Parts #MNC2105AA.
Are the new longer links the correct ones?
parallel would make more sense from a geometry standpoint ... guess you need to find out for sure whether the longer ones are just whatever uropart figured would fit.
"one inch longer" isn't going to allow anyone to help you. "the short one is X inches long from this point to that point" would let someone measure theirs and get back to you.
aholbro1
08-05-2021 05:02 AM
