2000 Jaguar Vanden Plas
I have a couple issues I've been trying to figure out and could use some help with. (1) None of my car door speakers work but the front and rear do. Are there any fuses that control the door speakers? (2) I cannot find the location of the horn fuse or relay. Is there a fuse for the horn? If so, where is it located?
R and L Investors, LLC (12-27-2023)
Capital,
I don't have direct answers for you, but these links may help.........
https://www.jaguarforums.com/forum/x...-boxes-211347/
http://jagrepair.com/images/AutoRepa.../jagxj2001.pdf
When you say "the front and rear" speakers work, do you mean only the A-post tweeters and the sub-woofer at the back work? The original Jaguar premium system has no "front speakers" other than the small A-post tweeters. I would first check directly at least one of the "non-working" door speakers to see whether it is perhaps blown and, if good, check the speaker wires from the Power Amplifier end to the speakers. If not in the speakers themselves, the problem could be in the amplifier or in the wires or the in-line connectors to the speakers. But, it is unlikely that wires to all 4 door speakers are bad. Possibly someone forgot to plug-in the in-line connectors, or the amplifier has failed. It is also possible that all 4 speakers are blown, one by one but only really noticed when the last one blew.
Joe15555
01-01-2012 09:46 PM
Thewaxmania
10-19-2011 10:09 AM
jagowner
03-31-2010 07:15 PM
