2000 Jaguar XJ8 power seat
Possibilities:
Check fuses. If I had more time, I’d look at the wiring diagram and show you where the fuse(s) is located. I believe the fuse for the seats are in the heal (under the rear seat) board fusebox.
Broken wires behind the seat switch pack.
Seat module. You could remove the seat module from the passenger side and find a way to unplug the drivers side module and temporarily plug in the hood module just to see if the seat moves for you.
FreedomFirst1776
07-22-2015 10:24 PM
