2000 jaguar xjr abs and traction control light
hello everybody, Im a newbie xjr owner, my car has 67k miles on itm and recently i was jumped into bump, an when i turn sport mode on after a while my front end suspension going down and and jumps on bumps, abs light and traction control light stays on, but after i turn the car off and start back on lights disappear. is it bad shock?
Welcome to the forum. I don't understand "jumped into bump" or "front end suspension going down". What happens if you don't turn sport mode on?
Check and see if you have active suspension. There would be a wire going to the top of both front shocks.
You need to have the stored codes read, but a generic reader will not do it. most foreign car specialists can read Jag specific codes.
Please visit the new member area and introduce yourself:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Sorry, my English is not perfect, I meant that i drove into a manhole, and front driver side corner visually sits about 2 inch. If i try to push this side of the car down, looks like its not even have a room to play, so its very firm, but when i driving car, the same side of the car dancing up an down. After I shut down the car it pulls up back again, and when i start it again abs and TC lights gone, until i start driving it at normal speed.![Icon Frown](https://www.jaguarforums.com/forum/images/smilies/icon_frown.gif)
