2000 VDP-SC "Check Rear Lights Error" - with right turn signal and braking
Old 07-23-2014, 10:53 PM
tlradcliffe's Avatar
Default 2000 VDP-SC "Check Rear Lights Error" - with right turn signal and braking
Any ideas why my "Check Rear Lights" error message displays when right turn signal is on & the brake pedal is pushed. This has been happening intermittently but regularly with my 2000 VDP-SC for the last few months.
I'm back to the jag dealer next week.
Thanks,
Terri
2000 VDP-SC
Old 07-24-2014, 05:41 AM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
Bad bulbs or loose bulbs in their sockets or wiring harness problem at the trunk hinge?
The following 2 users liked this post by sparkenzap:
Lear45 (07-25-2014), tlradcliffe (07-28-2014)
Old 07-25-2014, 10:38 PM
Lear45's Avatar
Check the bulbs if some have a silver base and others a brass base, the resistance difference is enough to cause a fault. Buy a box of new bulbs of the exact same
brand and the problem will likely go away. Sparkenzap is correct on additional
possibilities.
Old 07-28-2014, 08:56 AM
Thanks, guys! I will take your advice and check both bulbs and wiring harness.
Old 07-28-2014, 03:40 PM
Received 1,425 Likes on 1,067 Posts
If bulbs and wiring harness checks out - your issue could be in the turn signal stalk...
kurtomatic
02-12-2024 06:58 AM
MJ'S Jag
11-10-2022 08:14 AM
philwarner
08-30-2015 10:28 PM
nelsonht
08-30-2015 06:01 AM
Quick Reply: 2000 VDP-SC "Check Rear Lights Error" - with right turn signal and braking
