2000 VP Stuck in Valet Mode
Old 03-24-2008, 05:22 PM
Default RE: 2000 VP Stuck in Valet Mode
use the black key...close all the doors.. and the trunk.. and cycle the key in the door lock on the drivers door.. lock it then unlock..(make sure you hold it long enough so all doors lock and unlock). if you hold it long enough you will see the global opening feature.. as well..
if that doesn't work..open trunk with black key in the trunk unlock barrel.. it;s in the badge vanden plas.
Old 03-25-2008, 07:43 AM
Sounds like trunk latch may be bad. Possible fuse also. Likely trunk latch actuator.
Does it say valet mode on instrument pack when you start car?
Old 03-25-2008, 10:19 AM
Oh. In that case it is in valet mode....LOL.
Forget the latch problem.
If you cannot get it out of valet mode with key, it may be a trip to dealer.
Try disconnecting battery for 5 minutes and see if valet mode shuts off. When you reconnect battery, dont press valet button. Just try and open trunk. This is why having the remote is important.
Old 03-25-2008, 06:15 PM
You can buy them here http://originalkeyless.com/category.sc?categoryId=29
There are numerous threads on here about how to programme them. However, if your car is stuck in valet mode, you may have to take them to the dealer for programming.
Jagged-X
09-24-2015 05:08 PM
Dixie61
09-19-2015 06:29 AM
Andrew Fanshawe
09-14-2015 07:40 PM
Super Cat
09-09-2015 03:24 PM
stype40
09-09-2015 08:14 AM
Quick Reply: 2000 VP Stuck in Valet Mode
