2000 xj8 catalytic converters
heres a kicker for you techs i took my car to the muffler shop cause its throwing a catalist code he was stumped on how to get them off they are directly below the exhaust manifold and on the bottom of the converters its cast with no bolts how do i get these out is the first question......can i hollow them without messing up my car (they arent strict on emissions where im at) ?
There are bolts that connect the downpipe assembly (catalytics) to the exhaust manifold at the top. There is a mounting bracket attached directly to the downpipe assembly in front which bolts directly to the frame of the car. These bolts must be removed. Assuming you have disconnected the exhaust system from the convertors, disconnected the O2 sensor wiring, and removed all the bolts, the convertors should drop straight down.
You do not want to hollow out the convertors.
Also if you're car is running correctly, you'll find most cars actually pollute less from 2000 to 3000 RPM vs idle to 1500 RPM.
Aus V8S
11-13-2015 11:01 AM
dragonfly777
Regional
09-08-2015 01:39 PM
