2000 xj8 crankshaft pulley removal
Received 1,794 Likes
Its a press on piece on a key, so it just doesn't pull off. You'll need a puller, probably get a loaner from Autozone or O'reilly's. But once it starts, it comes rather smoothly. You'll need to lock your crank into position and cams so as not to loose time. Do a review of 'tensioner replacement' or 'timing chain replacement'. There's a detail in here using the Site Search... JagRepair.com - Jaguar Repair Information Resource ...from black onyx. Or do a search on site here, there are 10's of threads on this procedure.
"move the damper and collar 1 to 2 mm forward on the crankshaft."
"Remove the tool from the damper and then pull the damper forward and off the crankshaft: if necessary, lightly strike the damper to loosen it."
bob
wa3ra
04-12-2016 07:40 PM
03-13-2007 12:07 PM
